battery removal
  • battery removal
    Hi - I am new to the forum and need to replace the battery in my C8 Laviolette. I have gotten to the battery - have the battery tie down removed, the cables removed, the battery is loose but I cannot figure out how to get it out of the car without disassembling a lot of the front suspension - has to be an easier way. Any help greatly appreciated. On a separate subject - I want to
    change the oil in the engine but cannot find any way to open the rear other then to take all of the bolts out of the rear window. Is that how you get into the engine?? Thanks Gary 818-585-9118
  • #2
    Welcome to the forum and congratulations on your Laviolette! I am not sure about the battery but do know that it is necessary to remove the rear window in order to be able to change the oil.
    Winning on sunday, selling on monday!
    • #3
      Hi Gary, there are several people on the Forum that can help you. I have the shop manual. Please let us know that last 3 digits of your car, so that we can determine if it is spec A or B for the battery. The OEM spec for the battery is no longer available. There are very few batteries that will work. You probably will need to modify the battery holder to avoid that it is slushing around. Chris Mora will know what you need to get. I will text you today.
      • #4
        Please contact me if you have other questions; but the key to removing batteries if to flip it forward instead of trying to get the bottom out first. This is how I always succeed in removing a battery
        • #5
          I have a 2006 C8 Spyker Laviolette VIN XL9GB11H46Z363092 with a dead battery. Any suggestions on removing the battery (besides flipping it forward) and on what battery I should replace it with would be very much appreciated. My phone number is (918) 688-3456. Thank you, Mike Baab
          • #6
            Hi Mike, just send you a message through WhatsApp. Jasper
